'Active Hammering' is the next step
A project log for Spark erosion: Detailed view, simple machinery
Have a close look at how Electrical Discharge Machining (EDM) works and what can be achieved with a simple setup
norbert-heinzNorbert Heinz 11/22/2023 at 14:110 Comments
Adding active control over the hammering process will open the door to better engraving, even if the results aren't better with the first version of my mechanics:
The bugs are known, so let's improve the design...
