Maintenance
A project log for GPE's take over Trikka
Our indoor self-watering plant holder, a DIY creation inspired by the forward-thinking website, Mifactori Tikka
shreeyanemade2shreeyanemade2 07/26/2023 at 11:510 Comments
Weekly Care
  1. Check for clogs, leaks, or any visible damage.
  2. Regularly monitor the water level in the reservoir to ensure that it doesn't run dry, especially during hot and dry periods.
  3. Check and adjust the nutrient levels regularly according to the plant's needs.
  4. Regularly monitor the plants to check for signs of overwatering or underwatering. Adjust the watering schedule accordingly.
Maintenance and Cleaning
  1. Thoroughly inspect all components and clean if necessary.
  2. Remove any debris, roots, or sediment that may accumulate in the pipes, wicking material, or the water reservoir.
  3. Use a mild detergent solution or vinegar to clean the PVC pipes and containers to prevent algae growth.
  4. Replace the wicking material if it becomes clogged or starts deteriorating to maintain efficient water delivery to the plants.
  5. Promptly fix any leaks, damaged pipes, or connectors to prevent water wastage and maintain a consistent water supply.
Friendly reminder: If you use the system outdoors and experience freezing temperatures, drain the water to prevent pipes from bursting.
