[update 30 Sep 2024: clarify limit switches optional]
Thinking about making one of these things for yourself?
To get started with starting to get the getting started started to push out sufficient information to inform doing that...
...here's a rough rundown of parts to collect for the CNC mechanics. At this point I've iterated the XY stage design more than the Z axis so I can be a little more specific about that.
̶ ̶I̶'̶m̶ ̶w̶r̶i̶t̶i̶n̶g̶ ̶ I wrote about slicing and printing the printed parts separately. And the assembly process (forward-looking statement ahead...) as a richly illustrated and procedurally detailed Instructable -- which I expect will be not nearly as intricate as for the laser-cut version.
At this point, the scope of this info here includes the CNC mechanics (X+Y & Z axes), which will work in a very simple frame. Writing up stuff to stuff into the more fancy integrated desktop enclosure to follow.
Stuff
- PLA
- PETG
- or other material that can bear higher temperatures than PLA
- about a gram
- bearings
- 10 x LM6UU
- 6 for X+Y axes
- 4 for Z axis
- generics and generic "brands" appear to be all the same inconsistent quality; buy more (~2x) and select
- Fushi bearings
- look the same as generics, but
- two builders have reported receiving much better quality, so
- I ordered some and can confirm better-than-generic quality (late 2024)
- MSM bearings appear to be a clear step up from generics for not so much more coin
- (2 x 8 pcs cost <$1 more than 3 x 4 pcs at 16 Sep 2023 pricing)
- "real" parts with real specs cost real money, like $25 each -- or $320 (available with matched rod for $quote)
- 10 x LM6UU
- rods
- 6mm "linear motion shaft" (typically ground, hardened, and plated carbon steel)
- 6 x 120 mm for X+Y stage
- buy pre-cut to length e.g. here (2x 4pcs shipped to US for $13.62 -- 16 Sep 2023)
- or buy/find longer, e.g. 2 x 400 mm. and cut to length
- tbd 2 x 165-200ish mm for Z
- XY Motor+leadscrew
- two; one each for X & Y axes
- nameless generic product, often including "80mm stroke" in description
- searching "stepper 80mm stroke -nema" seems effective: google, duckduckgo
- with white plastic slider not bra$$ $lider and linear bearings
- there are two plastic slider types; don't care
- there appear to be two wire types
- 300 mm wires with 2.54 mm pitch connector
- 200 mm wires with 2.0 mm pitch connector
- the v0.9.0 STLs have details that favor the 300 mm/2.54 mm wires/connector
- some sellers like this one show drawings of two types A & B
- but I've received a "type A" unit with type B wires/connector, so might have to ask if care
- printed backlash adjuster ("bladj" STL) to be installed like this (different details; same procedure)
- M3 tap
- for printed backlash adjusters ("bladj" STL) for X & Y motors
- paperclips
- aka backlash adjuster locking springs
- two
- or other springy bendable wire ~0.8 mm diameter
- Z motor(s)
- ye olde 28BYJ-48
- 5V (i.e. not 12V)
- one motor
- works
- but I'm running mine too hot for a PLA pulley (using PETG)
- possibly could reduce drive current enough for PLA but I haven't tried
- two motors
- cheap insurance against some free-fall failure modes
- more likely able to run cool enough to use PLA for pulleys
- zip ties
- 4in, 18lbs
- how does the rest of the world specify cable tie sizes?
- tie straps ~2.5mm wide, ~1mm thick, at least 100mm long
- stronger 4in ties exist but I think the straps will be too wide/thick
- square heads (no gussets between head and strap)
- many
- ~50
- but multiply for trial fits, do-overs, waste, dis/reassembly, etc.
- 4in, 18lbs
- printed zip tie tools
- tool STLs to print
- "tietoolshort" -- short tool for short tie strap tails
- "tietooldeep" -- long tool for deeply recessed tie heads
- many of the tie heads are recessed below surrounding surface
- need a way to hold down tie heads while pulling tie straps tight
- my current practice is ... not refined
- better ideas welcome!
- cable tie tensioning tools exist but
- I don't have one
- all that I've seen pictures of assume free clearance around the tie head
- limit switches (optional)
- limit switches enable homing and soft limits[*] which are convenience features and not required to build a useful machine
- [* assuming grbl controller - others probably similar]
- three (XYZ)
- search "KFC-V-307" or "Camera A15"
- example
- 6 x small screws
- I have some scavenged 1.6 mm x 4.8 mm x 0.5 mm pitch
- pitch is more coarse than coarse M1.6 and I haven't found a source for any similar
- 1.6 mm is just a hair big for a mild interference fit, which is fine, but suggests 1.5 mm would be more "correct"
- #0-40 x 3/16 in. thread-forming screws for plastic look like a good fit and are widely available from many vendors -- in lots of 10,000
- McMaster-Carr lists #0-42 x 3/16 in more accessible quantities, but still kinda spendy with shipping.
- #0 diameter is 0.060 in. which is 1.5 mm
- found a source? please say so.
- wire e.g. 24AWG speaker wire, heatshrink, etc.
- X: 25 cm (10-ε in.) between switch body and connector housing
- Y: 13 cm (5+ε in.) between switch body and connector housing
- Z: tbd
- cables made to length because cable management designed into the XY stage assumes:
- wires routed internally to 2p "DuPont" connectors in the stage base
- 2p extension wires to the controller
- so the interconnect can disconnect at both ends -- for sanity in dense packaging
- gender reveal?
- I'm currently using female connectors on the switches because the Protoneer-designed CNC shield uses male headers and using connectors that could connect to the controller seemed like the thing to do -- plus M-F extensions where needed
- but might change to male pins on the switch side to avoid waving bare input pins (or motor power pins) around when unplugged -- then F-F interconnect required but nothing lost with connectors fixed in the mechanics that physically couldn't connect to the controller anyhow
- but the F 0.1in connector on 300 mm motor leads will still be F
- which is maybe another reason to design for the 200 mm / 2 mm leads instead
- and inline M connectors for the 2mm JST-PH F connectors exist (unofficially? i.e. appear to be not a JST product)
- and here's two PH-connected motors for <$17 (16 Sep 2023 pricing)
- mumble foo
- electronics
- if you don't already know/have what you want to use:
- ~$10 complete kits of (clones of) Arduino UNO + Protoneer CNC shield + Pololu A4988 stepper drivers exist
- example (whoa: $2-$5 "welcome deal"s for new AliExpress users; dunno if that's real or not)
- not DRV8825 for this low-current application
- but STSPIN220 drivers would rock for this low-current application... I think... maybe
- four motor drivers if you think you might want two Z motors
- i.e. not a Nano/v4 kit for three drivers only
- note all 0.1" male header pin connections, so plan for corresponding "DuPont"-type connectors
- wiring
- if you use a Protoneer-type CNC shield and get "type A"-wired motors then connections will be all M & F "DuPont" type wire terminations, which might be a welcome simplification, but...
- If you're aren't ready to make up "DuPont"-type terminations, then maybe get a bunch of M-F pre-crimped 30 cm & 50 cm wires like this and 4p & 2p housings, but...
- It looks like at least some sellers now (2023/2024) ship "type A" motors with "tybe B" wiring without comment or updating the type-A drawing or photographs
- "Type-B" motors (and now at least some if not all new type-A) use JST PH connectors with 2.0 mm pin pitch; JST designed PH for wire-to-board connections but someone has decided the world needs a mating inline connector should you want to keep and use the PH connector
- soldering wires to chunks of 40p header strip looks cheap and easy, but I haven't found a way that isn't fragile.
Paul McClay
