![](https://cdn.hackaday.io/images/original/4704191691476519424.gif)
Here's a gif showing how the mechanism operates - essentially as the handle is turned the bearings run along a cam surface. The bearings are on a lever tensioned by the extension spring. The cam surface is designed so that the deflection of the lever is linear with the rotation of the handle - and so the resistance is linear. This also means that the handle rotates in both directions, and snaps back smoothly to the centre
