• Development stage and plans
    Brad Arnett07/30/2023 at 02:23 0 comments
    Development Stage and Future Plans
    The entire project is built in Micropython, using several libraries including a Microdot-based webserver, a mDNS library, and numerous custom libraries designed for rapid board bringup and configuration handling.
    At present, the project is in the early stages of development and a roadmap is yet to be established. One of the primary next steps will be to devise a concrete plan that details the different stages of development and the features to be incorporated at each stage. The overarching goal is to create a versatile, easy-to-use, and highly customizable LED controller that stands out from the crowd.
    If you're interested in LED lighting and looking for a DIY project with a good balance of hardware and software aspects, then stay tuned for more updates on this exciting project!
  • Project Conceptualization
    Brad Arnett07/30/2023 at 02:12 0 comments
    Project Description
    This project aims to create a versatile, WiFi-enabled LED controller specifically designed for use with NeoPixel-compatible LED strips, with potential support for other LED types in future.
    The controller uses a Raspberry Pi Pico W or an ESP32 as the main computing module. Power is supplied either via the 3.3v power pins or through the built-in USB port. The controller is capable of driving up to 100 LEDs in a single chain, although the performance may vary based on your setup and whether logic level converters are used.
    In terms of control and interface, the project incorporates a Microdot-inspired webserver. While currently minimal, there are ambitious plans to introduce more features such as HTTPS and potentially websockets. This webserver provides a RESTful API for LED control, allowing changes to the color (RGB or RGBW) of a single LED or all LEDs in the strip.
    Moreover, an animation engine running on the second core of the controller board generates dynamic color changes based on user-defined Python functions. This offers the possibility of truly unique and customizable light displays.
    The project is designed to be user-friendly, with no special hardware or software requirements beyond a flashing program (esptool) and a browser for accessing the control page. It is also set up for optional physical interface via GPIO pins that can be configured for button control.
    On the connectivity front, an mDNS service is included to help users easily locate and connect to the controller on a network.
