Exploring The Decompressed SRAM
A project log for SNES Mario Paint Art Extractor
Transfer works of art from a Mario Paint cartridge onto an SD card
ansbaradigeidfranansbaradigeidfran 07/30/2023 at 12:550 Comments
The general layout of the decompressed SRAM is as follows:
The music track and settings are structured as described by BoodaW at NesDev.
The SNES uses bitplanes to store images, and follows the same approach in saving a Mario Paint image. (The series of YouTube videos on Super NES Features by Retro Video Game Mechanics Explained is a good primer on how this works.) Mario Paint images have fifteen colours (plus transparency), so are stored as a 4 bit-per-pixel bitplane.
The colour pallette is as follows:
This order nearly matches the order of the colour selectors on-screen when using Mario Paint, but note that White is in a different location. (It is positioned right-most inside Mario Paint.)
The background image is generally known to have an area of 248x168 pixels. This is indeed the visible image, but the images is actually stored (in Save RAM and also in the SNES' Work RAM) as a 256x174 pixel image, with a four-pixel transparent border. This allows the image to be stored as a series of 8x8 tiles: 32 across, 22 down.
The transparent border allows the picture to be centred on the TV, while still using the SNES's native tile layout. This border is replaced with a black & grey frame in-game, which can turn red depending on the user's actions.
The animation frames are stored in another 256x174 pixel bitplane, at offset 0x0000. The same bitplane is used for 4, 6 and 9-frame animations: the bitplane is subdivided according to the number of frames being used.Individual frames can be addressed by selecting the appropriate tiles from the bitplane, and have their own 4 pixel transparent border surrounding each frame. There is some additional transparency at the edges of the bitplane when 6 or 9 animation frames are used, to keep each frame the same size. The 6-frame bitplane has eight transparent pixels on the left and right sides (instead of 4). This means there's a whole column of unused/transparent tiles on either side of the bitplane when using 6 frames. The 9-frame bitplane is likewise, but has an extra 8 pixels of transparency along the bottom (one whole row of tiles).
Counting tiles from top-left, the relevant tiles for each size of animation frame is:
From 0x5800 to 0x5FFF, information is stored about displaying the animation frames on the background image.
Animations can be set to display at a particular point, or along a given path, by drawing a path of pixels in Mario Paint. This information is stored from 0x5800 onwards; a maximum-length path occupies bytes up to 0x5FF1. Each path pixel appears to require three additional bytes (after an initial zero-byte). The number of path pixels is stored at location 0x5FFA.
Location 0x5FF8 indicates the layout/number of animation frames in use. 0 indicates four frames, 1 means six frames, and 2 means nine.
Location 0x5FFE stores the speed at which the animation can run, from speed one (0x000) to thirteen (0x0C00).
Location 0x5FFC seems to hold some data (often 0x0100), but its purpose isn't yet clear. There's no clear use for bytes 0x5FF2 to 0x5FF7.
I've yet to identify how the path pixels are encoded in memory. Drawing paths in an emulator and inspecting the decompressed memory hasn't yielded any results yet.
