Panels added behind screens / 7 port hub moved
A project log for [Cyberpunk] Oni mobile command center
A CyberDeck build with a cyberpunk mobile command center design.
brent-wBrent w 09/01/2023 at 14:160 Comments
Panels were added to hide wiring and clean things up a bit in the back. The panel which housed eth0/audio/extra USB and charging port was modified and now only houses the audio and charging port. The extra USB port is now going to connect to a 1tb SSD which will be housed under the keyboard panel. The eth0 port will also be mounted in the keyboard panel. I am now on to reworking the keyboard panel which will be comprised of multiple smaller panels with some storage for some tools and antennas. I am also going to add a emblem to the outside of the case, but that's last on the list.
