So, I think I've decided to build a sim-pit for Kerbal Space Program. This is probably a terrible idea, but anyway...
While taking time to think about the bigger problems, I've been obsessing over the design and engineering elements that went into the hatch mechanisms. So, before any of the real work, I've created some 3D-printable parts including latches and hinges
When modelling the latch in OpenSCAD I included the kinematic model - essentially the movement of the latch is a parameter, and all parts move as if they were bolted together and to the appropriate pivot points. Why include this? The most vain reason is that it allowed me to see how the latch worked in motion - and to see if this was something that was interesting enough to spend the time and effort on. A side effect of this was creating some of the animated images you can see in other posts. A more practical reason is that it allowed me to test the model for interference - any point in the motion where one part wants to be in the same place as another part - obviously this would cause a problem.
Anyway, it's finished now, so I wanted to share a little bit of the process of creating the kinematic model. What it came down to was maths. Hideous, horrifying quantities of trigonometry. The YouTube channel ThisOldTony describes trigonometry as "shop math" - math for the machine shop - and while that's accurate, trigonometry really does feel like a blunt instrument at times. Is there a better way to do this? Probably, but I'm afraid I never learnt it...
I've finished designing a version of the latch that can be 3D printed, which is now underway. I'm sure I'll find some tolerance that is too tight, or some part interference, but that's just the way 3D printing goes in my experience...
In the meantime I wanted to share a couple of useful resources that I found online while researching this project. First, This page has a copy of a diagram of the Apollo hatch that shows a bit of detail how the hinges attach to the capsule - something that is missing in a lot of images online: http://heroicrelics.org/info/csm/cm-hatch.html
Lastly, this article by Lance Lininger and Kyle Gotthelf titled "Design and Test of the Orion Crew Module Side Hatch" focusses on the hatch design for the Orion spacecraft. There's a bit of comparison to the Apollo designs, but there's also a wealth of information including how the hatch lever gearbox works, and interesting problems like how the flexing of the hatch door under pressure affects the rods that open and close the latches. https://www.esmats.eu/amspapers/pastpapers/pdfs/2020/lininger.pdf
And here's the matching hinge. The NASA design uses a bewildering 6-bar linkage, and there's still a lot of work to do on this to fine-tune the lengths and angles, but the kinematics actually work in OpenSCAD
The latches used on Apollo Block 2 spacecraft are a pretty cool piece of engineering. Essentially, they're designed to lock closed in such a way that any force trying to push open the door is not transmitted beyond the latch itself - there's a handle that opens and closes the latch, but any force on the latch won't exert any force on the handle.
The Apollo hatch would use 14 of these - all attached with pushrods and bell-cranks at the corners.
I've modelled a version of the latch in OpenSCAD. At the moment this is mostly to work out how the kinematics operate, but this will form the basis of a 3d-printable version
