First version of the firmware is ready and deployment on ATtiny25. After upload firmware to MCU everything looks good. Now I will assembly everything together and testing.
Below I publish first version of the firmware.
* File: main.c
* Author: Grzegorz Wozny
* Created on 25 July 2023, 11:51
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define F_CPU 8000000UL
#define DIM_CH1 DDB0
#define DIM_CH2 DDB1
#define IC_CH1 DDB4 // Warm
#define IC_CH2 DDB2 // Cold
#define BUTTON DDB3
int cnt = 0;
int main(void) {
// Fast mode PWM
TCCR0A |= (1<<WGM01)|(1<<WGM00)|(1<<COM0A1)|(1<<COM0B1);
TCCR0B |= (1<<CS00);
// Enable LED5000 IC's
DDRB |= (1<<IC_CH1);
DDRB |= (1<<IC_CH2);
PORTB |= (1<<IC_CH1); // Disable Channel 1
PORTB |= (1<<IC_CH2); // Disable Channel 2
// Make PWM pins outputs
DDRB |= (1<<DIM_CH1);
DDRB |= (1<<DIM_CH2);
OCR0A = 0; // CH1
OCR0B = 0; // CH2
for(;;)
if ( !(PINB & (1 << BUTTON)) )
_delay_ms(20);
cnt++;
_delay_ms(20);
switch (cnt)
case 1: // 100% Brightness for Warm and Cold Channel
PORTB &= ~(1<<IC_CH1); // Enable Channel 1
PORTB &= ~(1<<IC_CH2); // Enable Channel 2
OCR0A = 255;
OCR0B = 255;
break;
case 2: // 65% Brightness for Warm and Cold Channel
OCR0A = 145;
OCR0B = 145;
break;
case 3: // 25% Brightness for Warm and Cold Channel
OCR0A = 50;
OCR0B = 50;
break;
case 4: // 100% Brightness for Warm Channel
OCR0A = 255;
OCR0B = 0;
break;
case 5: // 65% Brightness for Warm Channel
OCR0A = 145;
OCR0B = 0;
break;
case 6: // 25% Brightness for Warm Channel
OCR0A = 50;
OCR0B = 0;
break;
case 7: // 100% Brightness for Cold Channel
OCR0A = 0;
OCR0B = 255;
break;
case 8: // 65% Brightness for Cold Channel
OCR0A = 0;
OCR0B = 145;
break;
case 9: // 25% Brightness for Cold Channel
OCR0A = 0;
OCR0B = 50;
break;
case 10: // 0% Brightness for Both Channel. Disable ICs.
cnt = 0;
OCR0A = 0;
OCR0B = 0;
