Thumb wheel board
A project log for Reverse engineering Logitech MX Master
Ongoing project to reverse engineer parts of most productive mouse ever.
c00c00 08/07/2023 at 20:190 Comments
Thumb wheel board
This is daughter board that hosts thumb wheel, 2 thumb buttons, and 2 externally connected buttons with wires. It connects to the other button board via 12pin ribbon cable.
There are 2 ICs:
It would be quite hard to solder any breakout wires to the small board, but another board with buttons has a lot of test points that hopefully can be used instead.
Next step would be to figure out ribbon cable pinout, and connect wires to button board.
Plan is to use raspterry pi pico for prototyping.
