False trig solved
A project log for Inductance Meter Triggered solder Smock Remover
This is a project aimed at making a inductance dependent Fan switch with Arduino for removing solder fumes
franceFrance 10/09/2023 at 10:210 Comments
updated the code to be more efficient and removed the mathematical calculations that were slowing down the arduino.
Added new functionality that allows the coil to be connected to an external driving transistor instead of the Arduino GPIO pin, and the transistor type can be selected in the code.
