History
A project log for Water Waves To Sound Waves
The waves on water in lakes, rivers, swimming pools, and oceans might sound interesting if recorded and then sped up to become audio waves.
smokeyvwSmokeyVW 01/04/2017 at 00:080 Comments
A little history:
My first attempt used a float, potentiometer, a simple FM encoder, a handheld digital audio recorder, and some software. It worked pretty well on waves in a pool. Its range of motion was too limited, and the resolution was too poor to produce good audio.
The original version uses a 555 as a variable frequency oscillator. The frequency is controlled by a potentiometer with an arm attached to the shaft that supports a styrofoam float. As the water level moves up and down, the frequency continually shifts. The 555 output is recorded on a digital audio recorder. I wrote some c code that analyzes the recording and produces an audio file. A recording of about 30 minutes of water waves produces about 20 seconds of sound. It sounds kind of echo-ey, but with very poor resolution (like 5 or 6 bits), only just good enough to motivate me to improve the sound quality. (listen to the sound sample)
