Will Reflection Delay Work?
A project log for Water Waves To Sound Waves
The waves on water in lakes, rivers, swimming pools, and oceans might sound interesting if recorded and then sped up to become audio waves.
smokeyvwSmokeyVW 01/04/2017 at 00:100 Comments
The first experiment will be to measure the intensity difference between the initial pulse and the resulting echo. I will try it in open-air first, no tube involved yet. We'll see how that goes. If that doesn't work, I'll need to scrap this concept and try something else.
The "something else" might be to try amplitude modulation rather than frequency modulation or time delays. My recorder is 16 bit resolution at 44.1 KHz. It seems like I may be wasting too much resolution on time (samples) instead of on amplitude. It also seems like there ought to be a way to use both to obtain plenty more than just 16 bits.
