in the past week I was able to get in some time. My skills with a MIG welder are improving but still suspect.
![](https://cdn.hackaday.io/images/775301692285161697.jpeg)
This weld for example is straight with very consistent penetration on both pieces. Perhaps a bit thick, maybe.
But below welds on the front gusset look like the path of a drunk caterpillar.
![](https://cdn.hackaday.io/images/9700231692285279856.jpeg)
I will grind these and determine if I need to touch them up.
![](https://cdn.hackaday.io/images/7178331692285357511.jpeg)
Here is another view with more gussets, again some good some bad welds.
