A Table for Construction
A project log for Woody the Electric Four Passenger Bicycle
Woody is a scratch built quad wheel bicycle with four passenger capacity, with electric power to assist pedaling.
john-guyJohn Guy 08/10/2023 at 18:450 Comments
Professional (not me) bicycle frame builders have very sophisticated table, jigs and tools to ensure their frame is perfectly aligned. Me, well, I have some plywood.
A table with pivots was built, with adjustable height
And then covered with white paper. I drew lines for the major build points, and checked everything for square and level.
When I go to sensitive alignment elements, I added 4 legs to ensure the table was level so that a level could be used on frame elements.
