Actual Construction Begins!
A project log for Woody the Electric Four Passenger Bicycle
Woody is a scratch built quad wheel bicycle with four passenger capacity, with electric power to assist pedaling.
john-guyJohn Guy 08/10/2023 at 21:520 Comments
First I had to make the head tubes (tube which forks go through). Matching the bearing diameters to available tubing meant buying 2" diameter tubing with 1/4" thick walls. These should be strong.
The raw material, with a Sharpie for reference
Turned both, one has bearing pressed in.  While I had them on the lathe I sanded them a bit too.
