First I had to make the head tubes (tube which forks go through). Matching the bearing diameters to available tubing meant buying 2" diameter tubing with 1/4" thick walls. These should be strong.
![](https://cdn.hackaday.io/images/2851211691704249085.jpg)
The raw material, with a Sharpie for reference
![](https://cdn.hackaday.io/images/2881611691704265797.jpg)
Turned both, one has bearing pressed in. While I had them on the lathe I sanded them a bit too.
![](https://cdn.hackaday.io/images/6409441691704284155.jpg)
