I noticed that after a while the seat bottoms had warped extensively due to the tension of the upholstery webbing. so I redid the seat bottoms.
I laminated two pieces for the bottom with a predistortion and added two additional laminations at the front edge. Cleats now line the wholes sides, and the height was increased from 2.25 to 3”
![](https://cdn.hackaday.io/images/327761693537150974.jpeg)
