So on to the steering column and its linkage.
This is a small brace, I show it here because I was quite happy with how this turned out. The hole is a bit larger than 5/8", so I had to use a die grinder a bit.
![](https://cdn.hackaday.io/images/3101031694538115837.jpg)
Here is the side view of the steering column
![](https://cdn.hackaday.io/images/1077931694538116933.jpg)
And here is the view from the front. I'm not too happy with how clunky it looks though.
![](https://cdn.hackaday.io/images/2404341694538117456.jpg)
![](https://cdn.hackaday.io/images/7857001694538117539.jpg)
