Test Fit With The Big Screen
A project log for Airwave Inspector
Ryzen 7 cyberdeck boosted with Kraken SDR for mobile software radio fun powered by LiFePO4 batteries
andreaAndrea 08/15/2023 at 05:140 Comments
This is the original screen I intended to use, powered by 12V DC and having a discrete controller board it seemed ideal.
Unfortunately I could get this screen to light up and nothing else.
I'll continue to troubleshoot it and will return to this setup if I can.
You can see the first iteration of nylon "welding" which is actually quite strong.
Additionally this is 1mm vent holes, which seemed too small so I bumped them up to 2mm for the next iteration.
The PowMr screen didn't fit AT ALL and I had to hack at the hole to make it fit.
