Misc. Notes:
Usage:
Effects Details:
(copied from GitHub - the repo will be the source of truth for this project)
Mouse Effects
1. Reverb
Send your cursor flying! This effect adds a bit of momentum to your mouse cursor, so when you stop moving your hand, it will keep going in the direction you were heading. When this effect is active, the knob controls the "length" of the reverb (or, how long it will take to slow down to a stop after you've stopped moving).
2. Looper
Record a gesture with your mouse and play it back on a loop. Hold the right mouse button down to record, move around as you please, and watch loop playback begin as soon as you release. Use the knob to adjust the playback speed of the loop. Turn it all the way up to play it at 2.5X speed, turn it all the way down to play at -2.5X (reversed!).
3. Distortion / Noise Filter
This is a two-in-one effect. Turn up the knob (past halfway), and the pedal will add an increasing amount of random noise to your path of motion. Turn down the knob, and the pedal will apply a low-pass filter to your motion, effectively smoothing it out.
4. (Bonus) Crossover
Use your mouse as a keyboard! Use the scroll wheel to choose between characters, then tap the right mouse button to move on to the next. Hold the left mouse button + move left to backspace, move right to enter spaces, or move down to "hit" enter. You can also hold the right mouse button and move up/down to scroll through characters. The knob controls the speed at which the characters scroll.
Keyboard Effects
1. Tremolo
Change the "volume" of your typing on a time interval. Imagine an imaginary hand pressing and releasing the shift key for you on a fixed schedule. Turn the knob up to increase the switch rate between upper/lowercase. If you turn the knob all the way up, the effect will constanly force your typing to uppercase, effectively turning the pedal into a foot-powered caps lock button. If you turn the knob all the way down, the pedal will apply rANdOm/SarCaStiC case as you type.
2. Delay
Echo! (echo... echo...). This effect will repeat keystrokes on a time interval for you while it is engaged. The knob is divided into 4 zones, each corresponding to a delay interval time (from left to right: short, short-ish, long-ish, long). Within each zone, the knob controls the "feedback" - AKA the number of repetitions for a given keystroke. The rightmost edge of each zone will set the delay to repeat infinitely for maximum of 6 keys.
3. Pitch Shift / Harmonizer
Maps your keystrokes to... different keystrokes. The knob is divided into 3 sections. In the lowest section, the pedal will simply replace the keys you're pressing with those which are a fixed "distance" away (by their ascii number). So if the distance is set to 1, and you press the 'a' key, the pedal will instead type 'b'. If the distance is set to 2, pressing 'a' would yield 'c', etc. You can increase the distance between characters by turning the knob up. As soon as you turn the knob into the second section (about 10 o'clock), the behavior changes slightly. Now, instead of a "pitch shift", this becomes a "harmony" - the orignal key you pressed will be typed, as well as the shifted one. In other words, pressing one key will yield two typed characters. If you turn the knob into the third section (about 2 o'clock), the pedal will type 3 characters for each key you press: your original key character, one that is n characters away from that one, and another that is n characters away from the second. Think of it as a chord! You can turn up the knob within each section to increase n.
Use your keyboard as a mouse! The arrow keys move the cursor as you'd expect. The enter key emulates the mouse's left button. Use the letter keys to send the cursor flying in random directions. Yes, seriously. Modifier keys work as usual.
