One can add slow mode hardware to a ZX80, but I decided to buy a board with this designed in already.
2023-08-19
I bought these boards on eBay.
The logic board has some nice features. The bus signals are available on a holes for a header, allowing the dreaded RAM-pack wobble to be avoided. The board can take up to 32K RAM, so you don't even need an external RAM pack.
Power is from a USB-B socket. I'll have to check the electric current budget.
On the down side, the clock is a crystal-and-inverter which mean I can't change frequencies by swapping an oscillator can. I think that can be hacked!
The on-board SLOW-mode generator will need hacking to run with a 14.7456 MHz clock. I'll design something that can be easily switched between two frequencies.
![](https://cdn.hackaday.io/images/4239501692580691131.jpg)
The keyboard is on a separate PCB, so no mechanical stress is transmitted to the motherboard. It has the key letters but not the associated keywords.
![](https://cdn.hackaday.io/images/7172751692580690863.jpg)
The boards are due in about a week, so I shall get hunting for components.
2023-08-21
Printed out the circuit diagram and parts list. I have:
- Z80 CPU
- ROM
- RAM
- HC165 shift register
- HC74 D-type latches
- HC04 inverters
- HC138 one-of-eight decoders
- ACT86 xor-gates
- ACT574 eight-bit edge-triggered latch
What I don't have:
- HC541 (but I could use some ACT245 with a bit of hacking)
- HC08
- HC32
- HC125
- HC393
- HC4002
I could use some PAL chips to mop up the random logic. I have plenty and they are easy to modify.
2023-08-23
Boards arrived. I have soldered the key switches to the keyboard.
The motherboard is very packed.
2023-08-25
I fitted 0603 surface mount resistors where there are vertical through-hole resistors.
The ACT574 and HC165 chip are now soldered to the board.
2023-08-31
I have no HC541 chips but plenty of HC245 chips. So I took two HC245 chips and bent pin 1 under the chip and wired it to VCC. I then fitted it to the HC541 sites.
2023-09-27
Fitted SIL sockets for keyboard.
