Getting Going -mind my box going to line all the containers pulling every fin every heat transfer pipe out all the US and the neighbors always been I have access to rich people's e-waste wowE-Waste
A project log for Cyberdeck for 2024 Challenge
A multi-use modular cyberdeck ranging across the EMS. Sonar, RF, Ham, Sat, Robotics, Drone Control Center, Coding w/ prototypeing GPIOs / BB
neohackerjdneohackerjd 01/20/2024 at 14:340 Comments
I have three different size waterproof felony cases one has the wheels and is kind of Deep and already has means and an Ethernet Jack but they're not ip6 and they've cut to me that holes in them and I don't like it the way it is not very waterproof and so I'm picking my medium size one I'm going to use two layers a lot of aluminum fins on the interior in between the layers with aluminum heat blocks and and the piped heat exchangers to bring the gas I'm pulling them out of all kinds of E-Waste and repurposing them for my compartmentalize Chambers I want to reduce spurious RF interference from the various devices and transformers as well as batteries and crosstalk.
I find the interior with a aluminum tape and then I'm going to line all the individual Chambers as well and then I might cover it with an antique conductor coating just to prevent any type of accidental Short Circuit I have a 3D printer so a full Monster screen won't fit in there sadly so if I find a smaller one I'll put it in there otherwise I'm going to go with two 7-in touch screens for the raspberry Pi Force as I just happened to have the new the old connectors and don't feel like dumping a whole bunch of money on a bunch of brand new connectors and a pcie if I'm going to put a mini ATX Dell with ddr4 and i7 in there now I upgraded the processor and upgraded the Wi-Fi capabilities even though I'm going to connect it to a ASUS router that I will connect also to a plug-in G4 and I decided to go with both tripod mounted antennas which I can put away from my box and my tent which I'm going to put sides on and a waterproof cover the front will have a ip6 cover all the connectors will be ip6 I'll have high powered fans are very silent I got him out of old desktop one new one until Apple desktop Max and those are 12 volt fans that are ducted and they blow great so I'll do a u-shaped or some kind of shape downward facing joint on some PVC with a screen and shammy which Canadian Bush pilot shoes to remove water from the gas and have it run through a bunch of aluminum fins and then each separate separated like section with different components battery transformers alternators will be shielded and have their own tubing and exchange fins with a higher flow rate to move heat out of the box because I want to be waterproof I'm not sure about that I'm going to do the keyboard I might have a waterproof building keyboard into the surface and then Adele but it's all going to be wireless and wired everything's wired until I turn on the switch to make it wireless so Lauren I messedastic GPS the ability to transmit with two different hacker F1 with amplifiers and I I like devices Pluto version 2 with the fpga in the form armed cores all GPS disciplined with temperature control crystal oscillators to
I'm building my own at home double firewalled and plus plus security features that will use a 2080 with a AMD another really good AMD for A4 form factor and that one has a 900 but it's a really nice 900 from a company they stopped working with and then 9:50 and then I have a thousand series and then I just bought a purpose builts machine for building my own Minstrel 8x7bil X Orca (then merge CNN SigTourch Sig53, and one of the pre-trained version of their models whichever one functions the best and most effectively as well as all the open source data sheets as well as all the filings with the FCC the fs and EC and every other radio frequency based regulatory agency which requires that you file probably Australia and California etc the instruction manuals data sheets all the cubesat stuff that's under correct licensing and GitHub all the satellite stuff on GitHub I've already grabbed a bunch of textbooks that I own so that'll be for my use only so I have a bunch of textbooks on cubesats I have three textbooks on cyber warfare and electronic warfare, I have cubes that architecture cubesat radio frequency satellite Communication textbooks RF engineering and electrical engineering textbooks yeah I got a lot of that and I bought them so I can use them on my own local language model and then I'm going to import everything from the Gutenberg library that I think it's interesting from Play-Doh forward and the instruction manual for crackhead 7 python micropython best practices anything that I come up with with whichever creative Commons for cc sharps C++, Java everything I want to know and learn and have and I want to add Optical so I have a design for a passive radar system that beats the crap out of Rafael's.. I've been thinking about it ever since I thought about it and I looked at what was out there on the market and it's a joke almost that's all one piece of device in a new it was just an Orion Jetson in a military standards box with military connectors and that's all it was like oh my God I'm with their charging for that and then I'm going to use ip6 connectors that are aligned with a living room I want it to be a faraday cage so I have a ground in the bottom of the case that I'll have it connectable Spike that I can show into the ground so it really grounded and I'm using an ATX old HP power supply that was for us supposedly gaming board there was so far from gaming the only thing good about it was a 2080 which now reports in is the 2016 anybody have any idea about that it wouldn't surprise me this wouldn't be the first time this company has done funky things like with a Nokia phone that they changed in Microsoft that shouldn't have been able to run that version of their operating system and then opened it up and I found all kinds of funky manipulations and and changes to the chips I got in three of them I had my children thrown away and I put them I put my version on the bookshelf if I'm at my mom's house because it was my first real reverse engineering and the ICS had been actually accessed and had silicone taped on there with special tape they were doing stuff way wrong every thought I did that I was the victim of a 24-hour Day 36 days a year 7 days a week zero day I had three it guys working for me couldn't do anything they bounce in and out of routers all around me they cut through me like hot butter through knife they overclocked and Nokia and 91 so bad that like you put it near a speaker wire and the speaker with scream.
.. watch out for like different frequency sounds microphones and apple accessibility via Braille no kidding I turn that feature on flash with the visible command line around the bottom of the screen on the old Mini Mac and sure enough that's how they got there for a home and then also to the new HDMI cables in the hotels that can carry internet and then once through an IP camera that's how you got their foothold and it actually came in with a Catalina update in a Oracle virtualbox and this hotel had more access points than you could ever fill up that place was full to its capacity and with clients and I went to the clinic like the computer in the lobby and I put in a random password and up pop Visual Studio what's it doing on that computer like in the lobby..
There is a Chinese guy there checking out our local water company and I swear I'm not lying to you about the Art of War on my computer.
He saw me there that day I was there doing a masters in public health and they giving me permission to look at their Water analysis which was great they pulled it off because there was some arsenic in uranium in there but some guy had like the publication was wrong he put red in the yellow but it was so far below the WHIO guidelines been like at all on there he just wanted to make his publication look more interesting that water is better than you buying any bottles right out of the tap.
Long-term geological filters through granite or some of the best in the world especially high up and niched yeah I'm sure they still have microplastics cuz that's Nano and that's getting sucked up into the water cycle so nothing you can do about that or if it's like hidden water deep within the Earth that hasn't seen the light of day in a thousand years okay you're probably not going to find it there but this stuff definitely doesn't have anything bad for you as far as chemical goes cuz it's just been filtered through so much Rock.. yeah there was a tad bit of uranium and a tad bit of arsenic but that's normal for that kind of stuff and it was so low it was like wasn't mentioning even mentioning in the study of so that was so far beyond the who line way way and then he made it red and yellow so that his journal would stick out
So I've come a long way on my project very little funds by rating E-Waste pins here which are full of awesome stuff actually one of my firewalls is made from something I fished out of the E-Waste and two of my graphics cards and my switch that I'm going to use to link together some doctors in kubernetes and my Nas so that I can have different iterations for different uses I'm going to have my personal iteration or just going to be with few guardrails and safety tensors but then I'm going to make some for meta analysis and for doctors lawyers and one for signals intelligence which I don't think would be ethical for me to release especially with everything I'm going to add to it and I'm an ethical kind of guy and I don't want to give anybody to miss you I suggested to the cve people that we do a retro analysis to show the significance of ethical hackers and independent security researchers and I also think that you should write down your goals and like right down your own good ethics and jack up your own security so there's no accidental pre-release and have it signed by an independent party if that means a lawyer or an academic advisor or somebody a notary is sort of date on it so you can pull it out and say look this is what I'm doing here's my disclosure plan here my ethical plants here's my security upgrades here's the agreement between the team if we find out anything this is how we're going to disclose it and that would be a smart idea and I am a lawyer I'm not your lawyer and I'm probably not admitted in your jurisdiction but I'm admitted in many across all federal courts Supreme Court and then other countries.
None of those countries are non-natal countries because that matters to me one is neutral. 0 but that neutral country which I want to set up for that I've been because it's neutral because people will let us look at their stuff has the two best engineering schools in the world other than MIT and Caltech in the Colorado School of mines and I'm a great team builder and a great team player and I did the right thing with a whole lot of money so I've earned the trust in New York lawyer said I'm not telling you not to do the right thing meaning he was going to let me walk with it and split it with him and no if somebody does that to me it makes me even more irritated I'm a Kentucky and I'm a Montana and I wasn't raced that way and lawyers from there are not like that generally speaking.
I'm honored and proud to have acted professionally I'm not saying I was professional a great enough social life because it wiped out my emotional intelligence had to do anything extreme just not pain and not have suffering but I found Learning works extreme diving works 100 m with helium dying inside of a ship yeah that's good enough.
Learning about convolutional neural networks working with cig53 and sick torch and large language models and the new open source model and then I'm just waiting I'm already accumulating data to feed him my I'm going to give it a voice and I put speakers in microphones in every one of my rooms I'm going to attach it to my telescope I'm going to attach it to my camera and an antenna array.. I even have a camera that I pulled the IR filter out of and I really wish I had a thermal camera I have a 600 mm lens on a full framed Canon our wide angle lens and I have two of those cameras and I've got four sdrs but they're still not the right one said like two of them are great or three of them are great so the analog device when it's great it's got the fpga with two arms the hacker of ones are great I've got one that's a quarterback which is just on its own specifically kind of cool and then I've got I would love to have a crack in just because of geolocating if you had three of those instantaneously know exactly where somebody was especially if it angle of arrival to eliminate false path and infrared and I wish I had some collapsible dishes these guys are making them I would not I could order from China but I don't want to do that if anybody is an investor I got a bunch of ideas cuz I'm a creative creative guy I want to do away with passwords I've got consumer platform and I've got a professional platform consumer's just about authentication using two biometric methods and they come in pairs and it wipes if you even probe or to go through I'm going to put it now wires inside that plastic so thin it's a faraday cage you break one of those in a racist you probe that thing with a laser and a racist you attached to the battery prongs and erases it has a small LED in a little rubber cap it's all ip6 and it'll see if your pupil dilates he'll see if your blood's flowing your finger. You can even put blink five times really fast it wipes or hold your eyes open for 20 seconds or 10 seconds in your wipes and you just see how it doesn't work it's broken only my cables can make clones they're going to be shielded short and don't produce any or if the keys chip ideas DNA chip they call it.. I really thought it out the big version is a portable hard drive size you can either put two m2s in or five for grade 5 and you can either net or USB for it or thunderbolt it and it can hard work accelerate run its own OS so that it wipes your machine was done yeah and you just two different fpgas that can be reprogrammed with the newest stuff and they run with a true random number generator with two pass down each so you can't separate or isolate the voltages.. you even look at this thing wrong one's a keychain thing it'll be tough as heck on the outside but if you even try to get in there wipe gone and your home coffee you should get more than one and should have your safe and you're safe deposit box and you can clone them with my cable that's like just enough and has a military standard H level connector cable if you want to be rohammer-resistant IBM road 10 Ram that's the coolest thing ever is encrypted read 10 Ram 10 terabytes per core.
We should be building our encryption software Hardware to match the most complicated mathematical formulas and the largest keys possible not excluding them which n i s t has been doing they've thrown away keys because they were too complicated too big bandwidth is so much expanded now that we just need to grow that I need to make that more resistant I need to use the k level rad resistant and it had tamper resistance to that rad resistance row Hammer be ineffective the stuff should be totally untouchable no UV lasers it will sense it and turn it off wife it no fault injection through the power no all that stuff will turn it off even the OLED screen on there so you can change things so that you can have a micro nanofiber cover yeah you're not getting in this thing without wiping it? And you have special batteries with DNA chips in them you can take every step out and there's no more passwords they're absolutely terrible it's the biggest security risk there is we know it and then every firmware glitch should be a bug bounty and told to the National Security infrastructure immediately so they patch it fast like the next thing day it took 3 years for this company to patch the firmware and the guy likes the company he's from Montana he wouldn't go past their fixed they still thinks they're fixed is terrible because it's unethical but he still thinks that a bad guy could..
Joe Montana's for just being decent people I cried when I left cuz I know it wouldn't be back a long time I worked in with this great guy told me to be just the guy on the defendant see is one of the people I'm sworn to defend as a social worker most of my job and then the bad guys were like 10% violent guys okay I went after them without going hard but if you were just dumb and had a social problem or had posted my own event posture my stress is syndrome and it was it took forever to get him a place and the closest hospital he didn't have enough money to buy his meds so he can get himself arrested so we have to buy his meds man it's not the way to treat a veteran.
I'm not kidding you I worked with I'm a prosecutor I had a b**** I was friends with the cops and whenever they give me something that didn't meet the Lord tell him I tried to teach him explain him how to get it but yeah man that should never happen it took forever for us to get him out of bed and the closest veterans administration Hospital he has or had what I have now and I have it just as bad if not worse my parents heard it from a lavender Lebanese Beirut Lebanese doctor he didn't ask me if she said where have you been and who did that to you she knew right off the bat and she told him what I need and didn't listen to her didn't listen to me didn't listen to my former boss even they made up their own there about me I can't tell him because I was given ethics opinions that I can't tell anything about anything...
I'm working on my project with this little I've got I could really use some portable large satellite dish like like expandable umbrellas he's got to make man I would do a backflip for a couple different types I don't need those to be motorized I can move my foot and move them with the other like Leo's and stuff I'm not going to want to hit them all a certain ones and I'll be able to get the GEOS in the meals that I'm allowed to listen to and that's got automated connected to g predictor I can even connect to where she ridiculous their data and I can use a portable battery with some roll out really good solar panels a very small portable wind turbine that can put together in a very small thing I can throw in a stream or river..
I got my intent from the second hand store it's got to be a big one cuz I'm 6 ft tall and I'm huge I'm I've got it I got a army surplus middle of the road sleeping bag because I'm not going to go up in the snow but it gets cold at night so I got one close and I got something to eat I got a MSR multi fuel stove all I need are water purifier I'll be busy enough with my cool machines and I'll be able to connect to my large language model I'm building right now I got 128 gigs of RAM and I've got five and two raid on board slots 2 TB each I got an ass and a commercial switch I got another two complete Towers one with the 220 another one with a 650 and then I can make another one with the 1000 series with i7 I put the i7 and I've got the new rides and top of the line m a.m. 5 socket I can't do the Red River Mass Way Beyond me I wish I could but yeah I mean this one was 700 bucks just for the CPU. So I learned the medium side case I'm going to split it into two sections I'm going to put cooling ducts through it in like a snake pattern with hands and then heat pipes running from the different places cuz I'm going to shield each place so they don't cross talk and my ip6 cover with some hatches that have two breakout boards going to the raspberry Pi for experimenting chords accessories I got a multimeter in there I've got my meshtastic in there or the Laura TV I've got a battery monitor I'm using ATX power supply and I have plugins for solar panels and all that stuff I have the ATA broken out into 12 12 - 5 3.5 and then I'll throw in a variable it's a bad ATX I wish I could use the other one but it's better for me to use this one..,,, to I bought the circuit board I'm going to completely replace the absolutely underbuilt power switch but it does have does have a fuses thank goodness it's a terrible design it's hard to build a box around I would have not gone with the pre-made ATX power supply attachment and just cut them all off and done it by scratch....
Sometime I'm going to and I'm going to feed him into other converters and doctors and fly back transformers and transformers and I'm going to separated out and then I'm going to have a battery pack with lithium ion cells and I'm going to solder them myself put a battery control unit and myself.
I've got two high-speed duct fans from two former desktop apples that run 12 volts and I'm going to run them through a bunch of aluminum let me use liquid Metal on my cut a bunch of heat dispersion pads for every section and then I'll come from through a curved and then downward facing pray for the screen and shammy shirt Canadian Bush pilots for the gasoline through shirts it takes the water out. I don't feel like using the pellets like we do in the closed circuit rebreathers and stuff and I don't know how much more stuff to throw away and deal with maybe I'll give you if it's really wetter moisture humid in the summer is not so don't have to worry about it it's really that cool I need to maybe even bubble or through some of the lake or around cool but for the radiator in there that'd be a pretty cool idea use water cooling I have two options so bill then some water cooling pipes in it and also put a foil covered ip6 caps onions and if I choose use the pump pump cool River like extreme water out discreet quiet very cold water coming from glaciers.
I
