Raspberry Pi Pico 3 Channel WIFI current meter
Built a little board using MCS1806 linear hall-effect current sensors, attached it to a pico to make it WIFI enabled!
I wanted to try out the MCS1806 linear hall-effect current sensors. They have high isolation, are simple to interface, and paired with a pico means you can literally take your current sensor anywhere. The high amperage of the sensor means you *can* measure your appliances, but I'll have to see about the board thermal performance...
The board is currently populated with a MCS1806GS-3-05-Z, and a MCS1806GS-3-20-Z (i.e., the 5A version and the 20A version).  The 3rd position is not populated right now (cost reduction!).
I used 4.7 nF filters for the FILT connection, so the bandwidth on the current sensor is roughly 20 kHz.
Here is the github source:
github
  • 1 × Raspberry Pi Pico W Raspberry pi RP2040 eval board with WIFI
  • 1 × MCS1806 3kVRMS Isolated Hall-Effect Current Sensor with 500VRMS Working Voltage, ±2.5% Accuracy
View project log
