[X] Setting up Taipo-enabled firmware
A project log for AirBerries and SpaceExplorer
I should start using my £80 split keyboard and £40 spacemouse more than my £32 keyboard and £16 mouse.
kelvinakelvinA 09/16/2023 at 14:250 Comments
[16 Sep]
I was thinking that I was going to set this up and then make a log about it, but it's taking a bit of time so I thought a live-running log format would be better.
So far, I've tried to implement Taipo.c from a QMK source instead of a QMK->Vial fork and made everything barebones and turn things on, one step at a time.
It seems that Taipo and my keyboard works when RGBLIGHT_ENABLE = no in my rules.mk, and fails when set to yes, even without anything RGB related in the keymap.c. Unfortunately, turning rgblight off in my vial config doesn't fix the unresponsiveness issue.
Most recent commit.
