I wanted to copy-paste all of dilp's work, since it seems that he's stopped making commits specifically for Taipo. After looking around to see if I could just download a single folder in a repo, I somehow found my way into opening a PR for my own repo:
Unfortunately, RGBLIGHT_ENABLE = yes still doesn't work, but I found out that reducing Taipo_tap_timeout from the default 150 to 50 made things MUCH more responsive:
- TP_TLP's numerical keycode is the smallest numerical keycode, so var key is a number between 0 and 19
- The state to work on is then determined, as key / 10 would truncate to int 0 if key is less than 10 and truncate to int 1 if over.
- In dilp's actual layouts, the only things on _TAIPO are TP_ keys and KC_NO, so line 1181 probably deals with that.
- Not sure exactly what the rest of the first function is doing
- the second function seems to check if both the state timer is non-0 and passed the time allocated...
and that's about the extent of my understanding. I'm sure the code is dealing with things like holding the ' y ' combo being able to result in "yyyyyyyyyyy" sent to the host. I'm just trying to understand what could be the issue with RGBs and if I could implement something like TAIPO_PREFER_LEFT and TAIPO_PREFER_RIGHT so that it's possible to choose between a Keyboard Cat--esque typing style and a stenography-esque style.
I also tried to add unicode characters to my layout, but I got unexpected behaviour:
Finally, I could now start practicing in Ngram Type:
I started trying to alternate all the time, but I found it was easier to understand the finger movements if I just did one round with only my left and one round with only my right hand. Then I wanted to look ahead and see if there'd be any issues with my current setup before I hardcoded my neural network into a corner.
