It's been 7 months since I last wrote anything here (which is a shame), but my work has continued to progress. In fact, I've been thinking about setting up an automatic watering system that I can manage from my HA or automate altogether.
So here's the list of components I used to build the system.
- 1 esp8266
- 1 5V peristaltic pump
- 1 transistor 2N2222
- 1 1Kohm resistor
Here, the transistor acts as an automatic switch that we open and close using the HA application. Here is a diagram of the assembly.
![](https://cdn.hackaday.io/images/1115771694711747685.jpg)
M = pump
You need a 5V pump to connect it in parallel with the ESP, otherwise the assembly will not work. If you have a 12V pump, for example, you need to buy a 5V to 12V converter.
Here's a photo of the final assembly. This system works very well and allows the plants to be watered.
![](https://cdn.hackaday.io/images/1837221694711771975.jpg)
In blue, it's the transistor under the esp which saves space. (Sorry for cables, the cables are adapted to the location of the system in relation to the electrical supply, I had to dismantle the system to take a photo of the components).
Below is the code required in .yaml (HA language) to enable the system to work properly using the GPIO4 pin.
esphome:
friendly_name: espompe
esp8266:
board: esp01_1m
# Enable logging logger:
wifi: ssid: !secret wifi_ssid
password: !secret wifi_password
captive_portal:
switch:
- platform: gpio
pin: GPIO4
Finally, I was able to use this system for several weeks in a row, automating the watering of my plants. Now you know how to make your own automatic and home automation watering system.
PS: I've made other more basic protectors using LEDs or a 3D-printed wind turbine that I use to recharge external batteries. If you're interested, contact me as I don't think I'll be developing the projects here as they're simpler and more accessible to others on Youtube.
Re PS: Sorry for the translation if there are any mistakes or misunderstandings.
