After same break I wanted to continue but I noticed I lost the small magnets :-(. Reordering them and redesigning the cap went well. Gluing is horrible because they are so tiny.
The measurements showed that the magnetic field changes from the knob displacement (arround sample #1000) are a bit less than these of the earth magnetic field (sample #1500ff) but no signal saturation at all. I used again the stiff springs and they are for sure to stiff but should not be a problem for these first tests.
And then I started to work on the [Kalman filter](https://bastelbaus.github.io/Galaxy6D/signal_processing_concept/) with some docu. Not as straight forward to render math in github pages .. other thing to learn.
But most important I found the final name of my device, it will be called *Galaxy6D* :-) Had to changer some links but hope this name will stay till the end :-)
