Solar shield arrived, Amazon AWS via Sim7080G works!
A project log for Esp32-C6-Bug + Esp32-Bug-Eth
Playing with the new Esp32-C6FH4: https://www.crowdsupply.com/prokyber-s-r-o/esp32-c6-bug
allexokallexoK 04/05/2024 at 18:440 Comments
Today I received the first prototype of the Sim7080G board I designed earlier. No problems with connection to AWS, the code is in the repo. I had to change pin definitions a little bit, but almost no changes aside from that. I used 'eu-central-1' AWS endpoint, perhaps it solved the problem I encountered earlier(described in the previous log).
Best regards,
Alex
