Hackaday.io Hackaday.io
Sign up Log in
Jukephone
Repurposing a landline telephone into a jukebox with Raspberry Pi Pico and an Mp3 player
turiTuri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 9
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
461
0
2
4
Team (1)
  • turiTuri
Join this project's team
  • Source code
  • Blog post
completed project
hardware
raspberrypipico raspberry pi pico
This project was created on 10/04/2023 and last updated 3 years ago.
Description
I found a big button corded telephone and decided to paint it red and turn it into a jukebox. A Raspberry Pi Pico is used to read the keypresses, process the input, send the Mp3 player instructions via UART, and provide feedback through the LED and buzzer. The output pins of the Mp3 player are connected to the speaker inside the headset. There's also a 3.5" mini-jack port, to use headphones. The switch below the handset is used as a power switch. The whole Jukephone is powered by a lithium battery rechargeable via USB. I loaded the MicroSD card with 999 Mp3 files, organized so that there's one hundred per genre (except the first one). Specific tracks can be invoked by typing their number on the keypad.
Details
Components
  • 1 × Landline telephone With keypad matrix
  • 1 × Raspberry Pi Pico Or Raspberry Pi Pico W
  • 1 × DFPlayer mini (or MP3-TF-16P clone) MH2024K-24K, MH2024K-16SS and many more chips are supported
  • 1 × MicroSD card 8GB or more is recommended
  • 1 × TP4056 battery charger module
View all 9 components
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A compact CM5 carrier board that plugs directly into HDMI
Project Owner Contributor
Raspberry Pi CM5 TV Stick Lite
mbsmbs
Supplyframe DesignLab: 2022 Hackada…
A Raspberry Pi inside of a GameBoy retaining as much of the case as possible and using
Raspberry Pi Gameboy Utilizing Cartridges
daniel-johnsonDaniel Johnson
A night vision camera built with a raspberry pi zero w, night vision camera plus a 3.2" screen
Night vision camera raspberry pi
facelessloserfacelessloser
Breathing new life into a vintage Philco AM radio by turning into an entertainment system with Alexa and Raspberry Pi at the helm
Modernizing an Antique Radio
jacob-danielsJacob Daniels
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Jukephone", please tell us the reason.
Send message
Remove Member
