Driver boards arrival, first tests
A project log for Multipurpose Nixie Display
Displays whatever you want on three IN-12A/B displays.
mdasilvaM.daSilva 01/06/2017 at 16:450 Comments
3 weeks. I never had such a fast delivery time. I received 10 panelized boards, which means 20 boards total!
I was afraid the grooves weren't gonna be correctly made, but apparently they nailed it! I kept the default red colour, thought it looked nice.
The first test was with a Z573M. Man those tiny leads are a pain to insert into the board... But it worked great on first go! The logic signals came from an Arduino I programmed to scroll through the entire range, while blinking the decimal point.
I made three other boards with IN-12 tubes, they worked just as well.
Off to make something useful with this!
