Bypassing the BGW-320: Using an Azores COTS ONT -
How to Bypass the BGW-320 and Using an Azores WAG-D20
Most people with fiber have two ways to connect to the internet - fiber to an ONT, Ethernet to a gateway or fiber directly to the gateway. In this article, we will focus on how to bypass the BGW-320 and use a COTS ONT made by Azores.
Embark on a journey to liberate your internet connection from the constraints of the BGW-320 modem-router with this step-by-step guide by SimeonOnSecurity. This guide walks you through the process of bypassing the BGW-320 and implementing an Azores WAG-D20 COTS ONT for a more flexible internet setup.
Key Steps:
  1. Technical Aspects:
    • Introduction of Azores WAG-D20, an XGS-PON ONU/ONT with 10GE and 2.5GE ports.
  2. Device Access:
    • Default IP address: 192.168.1.1.
    • Correcting a factory typo in the Gateway address (192.162.1.1 to 192.168.1.1).
    • Serial interface login prompt via TTL serial interface (115200 8N1).
  3. Credentials:
    • Various login credentials for admin, guest, and factory access.
  4. Ethernet Interface:
    • Connection to the 10G ethernet port with a specified IP address (192.168.1.x/24).
  5. Customizing the ONT:
    • Retrieving essential information from the ISP Gateway or ONT (ONT ID, MAC Address, Equipment ID, Image Version, Hardware Version).
    • Telnet access to the ONT and entry into factory configuration mode.
    • Displaying and customizing settings using specific commands.
  6. Reboot and Enjoy True IP Passthrough:
    • Rebooting the ONT after customization for true IP passthrough.
  7. Troubleshooting and Additional Steps:
    • References to the 8311 discord and additional notes on Google Docs for further information.
Conclusion: The guide concludes with the assurance that, by meticulously following these steps, one can successfully bypass the BGW-320 and utilize the Azores COTS ONT to establish a connection with their ISP’s network. A note of caution is emphasized, urging users to be attentive when entering commands to avoid compatibility issues and potential connection failures. For detailed instructions, refer to the original guide.
  • 1
    Instructions
    Technical Aspects
    The Azores WAG-D20 is a XGS-PON ONU/ONT that comprises of a 10GE port along with a 2.5GE port even though it may be labeled on the device exterior as GE LAN. It may be acquired here .
    Azores WAG-D20
    Device Access
    The default IP address of the device is 192.168.1.1 and its Gateway address has a factory typo using a public IP address i.e. it shows 192.162.1.1 instead of 192.168.1.1.
    Once it boots, you need to hit enter to get a login prompt on the TTL serial interface (115200 8N1). This device has an A/B image system with an overlay partition holding any files you customize.
    Credentials
    • admin/ADMIN123!@# - Administrator login for web GUI
    • Guest/welcome - Guest login
    • test/default - Factory login
    Ethernet Interface
    Connect your client to the 10G ethernet port and configure it with an address in the 192.168.1.x/24 network like - 192.168.1.2/255.255.255.0.
    Upon running a port scan from 1-65535, you will notice some open ports:
    • Ports 23 & 8009 - Telnet, requires login, runs the CLI application.
    • Port 10002 - Unknown
    • Port 80 - WebUI, only two functions
    Customizing the ONT
    A BGW-320
    Now comes the important part i.e. changing some device info to make it compatible with your ISP’s network.
    First, grab the following information from your ISP Gateway or ONT:
    1. ONT ID
    • ATT BGW320-500: HUMAXXXXXXXX
    • ATT BGW320-505: NOKAXXXXXXXX
    • ATT 020:
    1. MAC Address (From device label)
    2. Equipment ID
    • ATT BGW320-500 HUMAX: iONT320500G
    • ATT BGW320-505 NOKIA: iONT320505G
    • ATT 020: BVMGZ00BRAXS020XA
    1. Image Version
    • ATT 320: BGW320_3.21.4
    1. Hardware Version
    • HUMAX ATT 320: BGW320-500_2.1
    • NOKIA ATT 320: BGW320-505_2.2
    Note: These are the OMCI values and not the ones from the web UI.
    Telnet to your personal ONT (telnet 192.168.1.1), login as test using the default password and run the command ’test’ to drop into factory configuration mode.
    Display the currently set values with the ‘show’ command:
    • show gpon mac
    • show sn
    • show equipment id
    Once done, customize the settings with the following commands replacing x with your device values:
    • set gpon mac xx:xx:xx:xx:xx:xx
    • set sn <insert ONT ID here>
    For HUMAX:
    • set equipment id “iONT320500G”
    • config ONU-G_Version "BGW320-500_2.1”
    For Nokia:
    • set equipment id “iONT320505G”
    • config ONU-G_Version "BGW320-505_2.2”
    Note: The last two commands should be applied from telnet logged in as the test user.
    After customizing, reboot the ONT and enjoy true IP passthrough.
    For more information on this topic, please check out the 8311 discord or the notes provided on google docs .
    Conclusion
    By following these steps one can successfully bypass the BGW-320 and use COTS ONT made by Azores to connect to their ISP’s network. However, be careful while entering commands and make sure to replace ‘x’ with your device values correctly otherwise, you may face compatibility issues which may result in connection failures.
View all instructions
