Inverse kinematic and inverse dynamics
A project log for BLDC Juggler
An attempt at advanced juggling with BLDC servos
josh-pieperJosh Pieper 11/01/2023 at 17:320 Comments
I implemented the inverse kinematics and inverse dynamics equations so that now the platform can be positioned at any orientation along a continuous trajectory.  I rigged up a simple 8 point demo with the translational degrees of freedom controlled by ruckig (orientation remains fixed at perfectly level), to show that it is working!
