Signal Strength Mode (Disco)
A project log for Bluetooth Devices Visualizer
Visually display the number of Bluetooth devices in your proximity
jeremygeppertjeremy.geppert • 10/25/2023 at 01:10•0 Comments
Signal Strength Mode is working!  The RSSI data comes back in the passive scan for devices as an integer. Based on what I found from a quick google search the following is the 4 color scale I used for this new mode:
>= -70  STRONG  Green
-70 to -85 GOOD  Yellow
-86 to -100 FAIR  Orange
< 100 POOR  Red
I should probably call this disco mode. I should be pretty awesome with a full grid of devices represented. Next is going to be adding a button to switch between modes.
