Beyond painting the pack and adding more physical details, I felt it was important to add some lights to the mix. The original pack is completely inert, so really, anything would have been an improvement.
As it just so happens, a common 8 x 5050 RGB LED bar (such as the Adafruit NeoPixel Stick) fit perfectly inside the "Power Cell", which would let me recreate the animated light effect seen in the film.
![](https://cdn.hackaday.io/images/6263591697422663928.jpg)
The bar was glued down into place, the wires were run out of a small hole cut into the bottom of the opening, and a 3D printed PETG lens was installed on top to diffuse the light.
