IT'S ALIVE!!!!!
A project log for Festo CNC (conversion)
Converting a scrapped Festo CNC rig into a (hopefully) working CNC mill for milling (mostly) aluminium
henrik-sorensenHenrik Sorensen 11/29/2023 at 22:360 Comments
Finally, I got the time to adjust the motor mount bracket and added a belt tensioner to it. Mounted the NEMA 23 motor and added the electronics (Arduino Uno + custom shield) + driver. Tested the Y axis movement using Candle. And it FRAKKIN MOVES!!!
