The painting begins...
A project log for Vintage Adamcraft Model RAF Seaplane Tender
I've been given a 70 year old, part-finished kit model boat and intend to finish it!
robgRobG 11/18/2023 at 17:080 Comments
The hull has now had a few laps of primer, filling, sanding, primer, etc. and the colour coat can go on. Nice. I've chosen to try and replicate the real-life ST 1502 which, rather helpfully, is quite local to me in Portsmouth - I might have to go and see her one day.
And while the painting progresses slowly, I can get the numbers and roundels cut from vinyl using the 3D printer (see my other project). The typeface is one I found on the web that's a close match to the photos of ST 1502 (post refurbishment), which I then tweaked a bit in Inkscape.
