• 1
    Connections for Components
    Lidar 1 (Power) to community Power
    Lidar 2 to Nano A4 (orange)
    Lidar 3 to Nano A5 (white)
    Lidar 4 (Ground) to community ground
    Lidar 5 to community ground (I2C Programming)
    Lidar 6 Unused
    Capacitor Positive to community power
    Capacitor Neg to community ground
    Bluetooth 1 Unused
    Bluetooth 2 (Power) to community power
    Bluetooth 3 (Ground) to community ground
    Bluetooth 4 TXD to Nano D2 (Pin 2)
    Bluetooth 5 RXD to Nano D3 (Pin 3)
    Bluetooth 6 Unused
    Battery Power to VIN (used 9V to test)
    Battery Neg to community ground
    Nano 5V to community power
    Nano ground to community ground
  • 2
    Sample Code
    #include <Arduino.h>
    #include <Wire.h>        // Instantiate the Wire library
    #include <TFLI2C.h>      // TFLuna-I2C Library v.0.1.1
    #include <SoftwareSerial.h>
    SoftwareSerial HM10(2, 3); // RX = 2, TX = 3
    char appData;
    String inData = "";
    TFLI2C tflI2C;
    int16_t  tfDist;    // distance in centimeters
    int16_t  tfAddr = TFL_DEF_ADR;  // Use this default I2C address
    int waitTime = 2000;
    void setup(){
        Serial.begin(9600);  // Initalize serial port
        Wire.begin();           // Initalize Wire library
        HM10.begin(9600); // set HM10 serial at 9600 baud rate
    void loop(){
          if(tflI2C.getData(tfDist, tfAddr)){
            HM10.println(String(tfDist/2.54)+" inches");
        delay(waitTime);
  • 3
    Download BLE app on IPhone or Android
    I used BLESerialTiny for IPhone to connect to BT05 (the HM10 Module)
