Soldering Notes and OLED Wiring Mystery
A project log for ArduAOA
Use BLE enabled Arduinos to collect Angle of Attack (AoA) information and display
tklenketklenke 11/20/2023 at 16:120 Comments
Follow steps to solder connections:
After making all connections, I was not able to successfully use the LED strip.  After some head scratching, I realized that I had connected the digital signal line to A4 on the Feather.  Turns out this is an INPUT only pin.  Duh.  So removed and soldered into A5.  Ops Chk OK!
