Distance sensors and Huskylens
A project log for Yozh robot
Small tracked robot, inspired by Pololu Zumo - but with many improvements
alexander-kirillovAlexander Kirillov 11/23/2023 at 21:290 Comments
Next project: use yozh together with a cheap AI camera from DFrobot, Huskylens.
Task: find a "container" placed on the field, read the tag on it (AprilTag), pick it up and deliver to one of locations depending on the tag.
I already had working circuit python library for Huskylens, so I used that.
But there was a number of gotchas:
Thus, I used mixed strategy: using distance sensors for initial detection and approaching the object; once we are close, use Huskylens to read the tag and do the final course correction before picking it up.
Here is the final result:
