Hunter dimensions
A project log for 3D printed blower
Failed attempt to make a cheaper blower.
lion-mclionheadlion mclionhead 01/31/2024 at 03:230 Comments
A new used hunter arrived, with enough spare parts to supply the rest of the lion kingdom's renting years.  The diameter of the squirrel cage was slightly bigger than the printed one.  It's height was much shorter.  The leading edges were still .5mm thick.
Its diameter without reinforcing ring was 212mm.  Its height was 51mm, including the reinforcing ring & disc.  It had 38 blades.  The blade cross section was 17mm x 17mm.  The thickest part of the blade was 2.5mm.
The mane problem continued to be the motor.  There was no spare hunter motor in working condition.
