Embedded Linux based LoraWan Balloon design
Introduction
This project is designed to build a linux based LoraWan HAB balloon. The idea of the project is to make an advancement of the current PicoBalloon communities.
Project Advantages/Disadvantages
As ever, re-inventing the wheel has it's own pros and cons. This section aims to answer FAQs on why this project has been built and designed.
Advantages
* Linux based - In the past, common sense would have assumed to have used low-power/arduino based microcontrollers. However, as chips have become vastly more efficient and cheaper in recent years (OK, that's a topic for another day!). This means that it has become sensible to start building using Linux. Advantages include being able to use Linux based drivers. For example the LoraWan interface is now a standard linux socket interface, and the HAM radio module can be interfaced with sysfs!
* Ease of development - Linux will allow GDB to be run on the end device for debugging, the environment is running ADB allowing code to easily be pushed or shell to be accessed. Multiple layers of _shit_ can be abstracted... Don't understand the FSK Lora Protocol or SPI interfaces? Fine. It's just a unix socket now! :)
* Ease of build - You can repeat this project with a soldering iron, a few thin wires and a swear jar.
* Sets a new standard of MVP (Minimal Viable Product) - The SDK and simple build means it can be used as a base design for quickly bootstrapping any future projects.
Disadvantages
* Linux based - Yeah, it's not a RTOS. Looking at the drift of WSPR.. eh, famous last words but should be fine.
* Ease of development - It vastly changes the paradigm compared to Arduino based solutions. Also, "just a unix socket" is quite oversimplified, for example Lorawan NWK (Encryption key) currently needs to set using ioctl system calls.
* Ease of build - WEIGHT!!!!!! - I will work on this one.
* Complexity - While fine once you get used to it... there is a lot going on here.
Network design decisions
There are 2 major providers of LoraWan coverage:
* TTN (The things network)
* Helium
Both have their own pros/cons.
I would consider TTN to be the more reliable choice, however seems to have an extremely strict fair use policy for the type of application I'm trying to work with.
Helium has what I would consider almost a "snake-oil"-esque blockchain based method of trying to encourage gateways - potentially creating unreliablity. However I feel this is offset by the generous fair use policy, and the fact that the coverage at 10KM in the air is pretty much to the horizon. So if one of the nodes is down, it really doesn't matter.
Therefore, Helium has been the chosen provider for this project.
Hardware design desisions
The hardware design is modular based, rather than a complete homegrown design to simplify development, and also ease of access to the project. (It's easy to reproduce at home!)
If significant advantages arise from a home developed board then it might be considered in the future. The weight difference, while lower is insignificant enough to not warrant the extra overhead and difficulty of access. Previous attempts of an in house designed circuit board using the F1C200S as a base design added complexity beyond what made the project enjoyable. (But easyeda.com I would recommend)
The hardware chosen has been based on multiple factors:
* Form size
* Power consumption
* Ease of hardware interface (The components should be able to work with each other without having to design an interface board in the middle to aid communication)
Hardware chosen
Main CPU Board
The Luckyfox Pico Mini B board was chosen as the main CPU interface board. (https://www.aliexpress.com/item/1005006175964407.html?spm=a2g0o.productlist.main.5.23e65e7fajW5dU&algo_pvid=d7ac3b67-3060-4390-9949-0ae884c76ab1&algo_exp_id=d7ac3b67-3060-4390-9949-0ae884c76ab1-2&pdp_npi=4%40dis%21GBP%216.24%215.62%21%21%217.52%21%21%402103080617001519217352442e2997%2112000036136791338%21sea%21UK%212760040230%21&curPageLogUid=gNBLw8xFaTQN)
This decision was made for the following reasons:
* It's absolutely tiny. (28.14mm x 21.00mm)
* It has a CSI connector (Allowing close to plug and play with adding a camera to the device)
* It's low power.
* It has an excellent SDK, which is now buildroot based complete with python3.
* If I attempted to build the circuit design myself it would take 20 attempts involving a fresh board being built and shipped (This has to be done using multilayer PCB/SMT components), and the project would just never get finished.
LoraWan communication module
A random Semtec SX1276 based module has been chosen from AliExpress. (https://www.aliexpress.com/item/1005002603901624.html?spm=a2g0o.order_list.order_list_main.5.5e371802KeFoSQ)
This design decision has been made for the following reasons:
* The SX1276 module has extremely good support
* The fact that it is a "Random" module doesn't matter, it has a SPI interface, and one would hope the board is tested - because it's a SX1276 board, any other board with the same chip should be pretty much one-to-one replaceable.
* If I attempted to build the circuit design myself it would take 20 attempts, and the project would just never get finished.
GPS Module
Generally modern GPS modules are simply UART based, use similar chipsets and have essentially all become unified since they became integrated into smartphones. I didn't take much bother into researching this one. They should in theory neary all just be hotswappable.
*Update*: No, no they are not. Added gpsd as a common interface.
Camera Module
This one needs research. I just picked the smallest, lightest camera I had on hand (It came from a ESP32 kit). Might not be the best solution power wise. This section might need an update.
*Update*, who uses a 20 Pin non-conformant MIPI/CSI interface on a dev board?!? Luckfox.. Otherwise the best dev board i've ever worked with :/
Notes on design documentation and Source code
The linux module used as the central processor is based on the LuckyFox Pico Mini B. Hence the basis of this git repository is a fork of their SDK for ease of updating any bug fixes for the board. Where there have been significant code changes, the README.md from LuckyFox have been renamed with a _luckyfox.md appendage.
As the base design of this project is a fork of the Luckyfox Pico SDK (https://github.com/LuckfoxTECH/luckfox-pico) a lot of the project gets hidden within their design of how an embedded SDK design should look like (Which, actually, to be fair is pretty decent IMHO).
I have placed design thoughts within the ./doc directory within this repository.
Project status
* [_COMPLETED_] It boots into Linux/Buildroot system.
* [_COMPLETED_] SPI working with Semtec sx1276 FSK Modem.
* [_COMPLETED_] I2C working with Si5351 Pulse Generator.
* [_COMPLETED_] UART working with uBlox GPS Module.
* [_COMPLETED_] GPS Works, gpsd installed.
* [_COMPLETED_] CI/CD Works.
* [_TESTING_] WSPR Working, Still requires real-world tests.
* [_IN PROGRESS_] Lora works, LoraWan not tested, added EU region, missing others in kernel driver.
* [_IN PROGRESS_] LoraWan MAC to IPv4 Bridge.
* [_TODO_] "Glue" shell scripts to tack everything together.
* [_TODO_] CSI Camera Interface with CSI/MIPI camera.
* [_TODO_] Camera Images to Lorawan Packets.
* [_TODO_] Reduce physical weight (Daughter Board?)
