- Create PX-8 management tools. And maybe later universal tools for both. The PX-8 has a weird architecture with a main CPU, slave CPU and sub-CPU, but in the end it is just an other BIOS call.
- Modify the PFBDK firmware to be selectable for one or two disk terminals. Each terminal has one (PF-10) or two (TF-20, TF-15) disk drives. Now PFBDK claims all four disk drives. Unknown is how it responds to other functions than floppy related.
- Modify the hardware for a second serial port to daisy-chain to another device. Useful when the actual video interface (Oval UD-80) becomes available. How the extra serial port is wired is visible in the PF-10 schema. The EPSP interface is an implementation of CP/M-NET, so historical relevant there too.
- Change the program set to integrate the PFPW4 functionality into the PFMNT4 program.
- The default configuration is having the four images D.IMG to G.IMG mounted. My idea/plan is to make a submit file changing this configuration on the default drive A:, but it didn't happen yet. The advantage is that no changes are needed to PFBDK and it uses standard CP/M tools.
