The module's pinout seems to be:
- 3V3 - module power supply
- GND - common ground
- OUT - outgoing light voltage
- IN - incoming light voltage
- CDS - light detect / module disable feature
As far as I can currently tell, it works something like this: if the CDS is not pulled low, the module will send out pulses and measure their return times. If a change in return times is detected (i.e. something in the path of the radio waves has changed position), it will connect the IN and OUT lines (most likely with a MOSFET). So if there's a light connected to the OUT line, and an external power source (4V - 28V) is connected to IN, it will light up. The OUT line will go low after a short period of time (a few seconds) if movement stops. Of course, GND lines must be connected together.
I'll need to experiment with it some more.
OUT is digital logic high with motion. There is no point trying to use this with an analog input.
https://github.com/jdesbonnet/RCWL-0516
http://forum.hobbycomponents.com/viewtopic.php?f=73&t=2181
