Result
A project log for 7 "screen Display Based on LVGL
different resolutions will affect the display on the same size screen
makerfabsMakerfabs 12/13/2023 at 03:570 Comments
Step 3: Result
From the video, you can see that the resolution 1024 version has higher display effects, while lower FPS, and the resolution 800 version has lower display effects, while higher FPS.
The result is that the high-resolution version is better suited for static displays, while the low-resolution version is better suited for dynamic displays.
So which version do you prefer?
