Step 2: SquareLine Design
A project log for ESP32-S3 Digital Combination Lock Based SquareLine
In this article, I'm going to make a digital combination lock, using Squareline_studio and MaTouch ESP32-S3 Rotary IPS Display with Touch 2.
makerfabsMakerfabs 12/13/2023 at 05:450 Comments
Choose the Arduino and enter in parameters. According to the features of MaTouch ESP32 S3 2.1 Rotary TFT with Touch, the resolution is 480*480, the shape is a circle, and the color depth is 16-bit.
Add the images and fonts you like to assets, and then it allows you to select them and widget components to design the scenes. After, clicking the widget of the list on the Hierarchy panel, you can modify the parameters of the select widget on the Inspector panel, all is determined by your preference.
Here, I'd suggest selecting some photos that hold cherished memories for both parties.You also can place some words you want to say to other person on the second screen, so they can discover them upon unlocking.
Detailed guidance
