Step 2: Firmware of Clock Screen
A project log for World Clock& Weather Monitoring Design With LGVL/S
In this article, I'm going to make a screen that displays real-time time and weather conditions in some capital cities.
makerfabsMakerfabs 12/13/2023 at 10:040 Comments
Since I did not use the TFT_eSPI library, it is needed to delete or comment all the codes related to the TFT_eSPI library.
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    tft.begin();          /* TFT init */
    tft.setRotation( 3 ); /* Landscape orientation, flipped */
When I use the GFX library, it is needed to define the GFX Library For the Arduino Interface pin.
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
    GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
    40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
    45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
    5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
    8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
Arduino_RPi_DPI_RGBPanel *gfx = new Arduino_RPi_DPI_RGBPanel(
    bus,
    SCREEN_W /* width */, 1 /* hsync_polarity */, 40 /* hsync_front_porch */, 48 /* hsync_pulse_width */, 128 /* hsync_back_porch */,
    SCREEN_H /* height */, 1 /* vsync_polarity */, 13 /* vsync_front_porch */, 3 /* vsync_pulse_width */, 45 /* vsync_back_porch */,
    1 /* pclk_active_neg */, 16000000 /* prefer_speed */, true /* auto_flush */);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
    if (touch_has_signal())
        if (touch_touched())
            data->state = LV_INDEV_STATE_PR;
            /*Set the coordinates*/
            data->point.x = touch_last_x;
            data->point.y = touch_last_y;
        else if (touch_released())
            data->state = LV_INDEV_STATE_REL;
    else
 The raw code.
