The Power Supply
A project log for Designing a Modern Tubeamp (Matthews 14)
Ground up design of a guitar tube amp using old and new technology.
collin-matthewsCollin Matthews 01/01/2024 at 02:520 Comments
This should have its entire own project on HackaDay, and maybe soon it will.
Usually a tube amp needs a high voltage transformer, I decided to attempt something different here since early on I was unsure about the final voltage I would want, as well as wanting dedicated 15V rails for op-amps and other lower voltage circuits.
I started development of a solid state power-supply in 2018. Early on I tried a cheap eBay high voltage module, after destroying two at a very low load I decided to move forward and make my own.
Some of the requirements that developed over time:
Below is the first revision of the board, it only had a high voltage flyback and a buck converter for the heater. It lacked the 15v regulation and negative bias outputs that I would later want. The layout was not great and I had stability issues due as well.
For these kinds of requirements, the only option was to wind a custom transformer with multiple windings. Winding a flyback transformer, and air gaping it with Kapton. Later transformers used parallel primary windings to reduce the skin effect losses, as well as multiple auxiliary windings for the negative bias and op-amp voltages.
Lots of engineering, math, testing and measurements later... I eventually ended up with this:
A roughly 60W power supply 88% efficient under nearly full load. meeting all the requirements above. Looking back I would now design the supply to run off of 120V instead of 24V. I would also move to a GaN switching FET. But this works...
