Step 1: SquareLine Design
A project log for Christmas color light controller
In this article, I'm going to make a Christmas color light controller, using MaTouch ESP32-S3 Rotary IPS Display with Touch 2.1 “ST770
makerfabsMakerfabs 12/25/2023 at 09:190 Comments
Choose the Arduino and enter in parameters. According to the features of MaTouch ESP32 S3 2.1 Rotary TFT with Touch, the resolution is 480*480, the shape is a circle, and the color depth is 16-bit.
Add the colorwheel, switch, and buttons on the interface, the color wheel for getting colors, the switch for light switch, and buttons for timed triggers,and you can modify the parameters of them on the Inspector panel. After that, you can select some other widgets to decorate your interface, all is determined by your preference.
