Step 3: Firmware
A project log for Christmas color light controller
In this article, I'm going to make a Christmas color light controller, using MaTouch ESP32-S3 Rotary IPS Display with Touch 2.1 “ST770
makerfabsMakerfabs 12/25/2023 at 09:270 Comments
Since I did not use the TFT_eSPI library, it is needed to delete or comment all the codes related to the TFT_eSPI library.
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    tft.begin();          /* TFT init */
    tft.setRotation( 3 ); /* Landscape orientation, flipped */
When I use the GFX library, it is needed to define the GFX Library For the Arduino Interface pin.
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
    1 /* CS */, 46 /* SCK */, 0 /* SDA */,
    2 /* DE */, 42 /* VSYNC */, 3 /* HSYNC */, 45 /* PCLK */,
    11 /* R0 */, 15 /* R1 */, 12 /* R2 */, 16 /* R3 */, 21 /* R4 */,
    39 /* G0/P22 */, 7 /* G1/P23 */, 47 /* G2/P24 */, 8 /* G3/P25 */, 48 /* G4/P26 */, 9 /* G5 */,
    4 /* B0 */, 41 /* B1 */, 5 /* B2 */, 40 /* B3 */, 6 /* B4 */
// Uncomment for 2.1" round display
Arduino_ST7701_RGBPanel *gfx = new Arduino_ST7701_RGBPanel(
    bus, GFX_NOT_DEFINED /* RST */, 0 /* rotation */,
    false /* IPS */, 480 /* width */, 480 /* height */,
    st7701_type5_init_operations, sizeof(st7701_type5_init_operations),
    true /* BGR */,
    10 /* hsync_front_porch */, 8 /* hsync_pulse_width */, 50 /* hsync_back_porch */,
    10 /* vsync_front_porch */, 8 /* vsync_pulse_width */, 20 /* vsync_back_porch */);
To create a group use lv_group_t * g = lv_group_create(), to add an object to the group use lv_group_add_obj(g, obj), and to associate a group with an input device use lv_indev_set_group(indev, g);
/*Initialize the (dummy) input device driver*/
    static lv_indev_drv_t indev_drv;
    lv_indev_drv_init(&indev_drv);
    indev_drv.type = LV_INDEV_TYPE_POINTER;
    indev_drv.read_cb = my_touchpad_read;
    lv_indev_drv_register(&indev_drv);
    // encoder
    static lv_indev_drv_t indev_drv2;
    lv_indev_drv_init(&indev_drv2);
    indev_drv2.type = LV_INDEV_TYPE_ENCODER;
    indev_drv2.read_cb = my_encoder_read;
    lv_indev_t *encoder_indev = lv_indev_drv_register(&indev_drv2);
    lv_group_t *g = lv_group_create();
    lv_group_add_obj(g, ui_Colorwheel1);
    lv_indev_set_group(encoder_indev, g);
void pin_init()
    pinMode(TFT_BL, OUTPUT);
    digitalWrite(TFT_BL, HIGH);
    pinMode(ENCODER_CLK, INPUT_PULLUP);
    pinMode(ENCODER_DT, INPUT_PULLUP);
    old_State = digitalRead(ENCODER_CLK);
    attachInterrupt(ENCODER_CLK, encoder_irq, CHANGE);
    Wire.begin(I2C_SDA_PIN, I2C_SCL_PIN);
void encoder_irq()
    if (State != old_State)
        if (digitalRead(ENCODER_DT) == State)
            counter++;
        else
            counter--;
    old_State = State; // the first position was changed
void my_encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data)
    if (counter > 0)
        data->state = LV_INDEV_STATE_PRESSED;
        data->key = LV_KEY_LEFT;
        counter--;
        move_flag = 1;
    else if (counter < 0)
        data->key = LV_KEY_RIGHT;
        counter++;
        move_flag = 1;
    else
        data->state = LV_INDEV_STATE_RELEASED;
    // if (enc_pressed())
    //     data->state = LV_INDEV_STATE_PRESSED;
    // else
    //     data->state = LV_INDEV_STATE_RELEASED;
